Question How to edit the User-Legend?
I seached in the Web, but I didn't found the right answer how to edit this.
The first thing I want to change:
I want to remove "Supermoderator" & "Moderator"
The second thing I want to Change is the Color of the other ranks in the Legend and the color of the usernames with that rank.
I'm quite new to web-development, so I need an explanation for newbies
Thanks a lot!
Kind Regard
DopiGFX
- Thank you received: 2545
Use additional this code if you want to hide some ranks.
Example:
Add rank
Lets say I want those all in the legend: Administrator, Moderator, Friend, Super User, User & Banned
Every rank below Moderator shoul only be cosmetically, so they should only be colored and nothing else.
Is it possible to do that?
Btw: Thanks for the quick help!
Kind Regards
