Solved Quick reply out of screen
6 years 4 months ago - 6 years 4 months ago #213594 by Django29
Hi
When we open a quick reply field, the Submit button at the bottom is not visible.
And we can't scroll this page.
What can be the problem ?
Last edit: 6 years 4 months ago by Django29.
6 years 4 months ago #213597 by 9themestore
Hi Django29,
Did your forum live? Please post your forum url here if It lives, we will help you check and and find the solution for this issue.
6 years 4 months ago #213598 by Django29
Replied by Django29 on topic Quick reply out of screen
I just found this discussion , with a solution.
Add this in the custom.css :
.modal-open {
overflow: auto;
And it works.
I was not the only one having this problem.
Thanks for answering.
