Question Submit button not working properly
6 years 6 months ago #213176 by btc
I'm currently preparing to migrate a website from one hosting company to another. I've been uploading copies of the production website on the old host to the new host to test things out and make adjustments. So far everything seems to be OK except for a serious issue with Kunena (which is an important part of the website).
After entering a message into the box and clicking on Submit, the page hangs - this continues for a few minutes until the server times out. However, the new message has been written to the database tables. If I refresh the page I see the success message at the top of the page, but the form for submitting the message is still displayed, with the text of the message still in it.
The same thing happens when writing a message using Kunena Discuss.
This doesn't happen on the production site, even though the content of the website is identical, the only differences are database name and login details etc. The new host is running PHP 7.3.17, the old host PHP 7.3.3.
I've tried changing browsers and I've tried changing Joomla templates - browsers make no difference, but there is one template where the message posting works normally - Protostar. However, the Protostar template doesn't suit my website - though if necessary I might be able to adapt it, though it would be non-trivial. I've tried Shape5 Vertex and Joomlart T3 Blank, but the problem occurs with them too. If I can't get Kunena to work, I'll have to abandon moving to the new hosting service.
Do you have any idea what might be the cause? Is there some way I can use the Console to trace the problem?
(PS the report below says
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : forte | author: Shape5.com | version: 1.0.3 | creationdate: October 31th, 2019
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.3 | creationdate: 2020-03-31
Kunena template params:
Kunena version detailed: Kunena 5.1.16 | 2020-03-17 [ Pallene ]
Third-party components: CommunityBuilder 2.4.2
Plugins: Search - Kunena Search 5.1.1 | Content - Kunena Discuss 5.1.1
Modules: Kunena Latest 5.1.1 | Kunena Search 5.1.1
6 years 6 months ago #213177 by btc
Another discovery:
Protostar + Blue Eagle 5 - works
Protostar + Crypsis - doesn't work
Strange!!
6 years 6 months ago #213178 by rich
If errors occur after copying to another hosting, it is mostly the cache that causes them. If you copy a complete web page, it copies also the cache with the infos from the old address. Empty all caches, then try again.
6 years 6 months ago #213181 by btc
Thanks Rich. I did clear the cache, but it was empty anyway. I used Akeeba Backup to move the website and Akeeba doesn't copy cache files anyway.
6 years 6 months ago #213182 by rich
Let's summarize:
Blue Eagle works with all your Joomla templates
Crypsis works only with Protostar
1. It could be possible a file has been broken during the move and it helps if you install Kunena over it.
2. Possible is a conflictt between Crypsis and Shape5 Vertex as well Joomlart T3 Blank
3. Script or CSS compression causes an error
Do you have any CSS or script optimization tools on your page enabled? If yes, disable these and afterwards try to send a message.
Choose Crypsis and the Shape or Blank template and open the console (tab network). Then click on Reply. Now check which scripts of the template running. Block the scripts one by one with the browser tool and every time try to submit a reply.
Try the same with the css files. Maybe you can find out which file cause a conflict.
6 years 6 months ago #213188 by btc
Thanks, Rich.
Eventually even Protostar stopped working with either Kunena template - strange, as nothing else had changed.
However, thanks to your advice, I've now identified the script that's causing the problem, but I'm not sure where that leaves me because it's part of Advanced Modules Manager, which I regard as an essential tool.
If I block /media/advancedmodules/js/frontediting.min.js everything works fine.
There's another frontediting script, which is media/system/js/frontediting.js.
As I said before, this doesn't cause a problem on production website, which is hosted elsewhere.
Time to create page: 0.177 seconds
