Question Attached Files Instantly Orphaned
6 years 6 months ago #213041 by TempleOS
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.16 | creationdate: 2020-03-17
Kunena template params:
Kunena version detailed: Kunena 5.1.16 | 2020-03-17 [ Pallene ]
Plugins: None
Whenever a user uploads an image, on the forum it shows as "You do not have permissions to access this page."
The images are in the correct folders, however they do not appear in the backend despite the backend showing that there is 5 images.
Looking at the diagnostics, the attachmentOrphaned test shows failed, and cleaning up the orphaned files just deletes the images. Why does this happen?
6 years 6 months ago #213042 by rich
I'm sorry, it's a bug. That happens when user leaves the editor during create the message. After that, the picture cannot be assigned and get the message id 0.
github.com/Kunena/Kunena-Forum/issues/6620
