Question How to disable thumbnails in posts?
6 years 8 months ago - 6 years 8 months ago #212655 by coldwire
How can I disable the thumbnails at the bottom of a users post?
I'm using the latest version 5.1.16.
Last edit: 6 years 8 months ago by coldwire.
6 years 8 months ago #212661 by rich
In principle its fixed but it seems does not works as it should if you use the button "Insert All" for more images. When you insert the images one by one the thumbs should be hidden (see here).
6 years 7 months ago #212900 by coldwire
Thank you Rich.
Unfortunately even if it's one by one, the thumbnails are still there.
Is there anyway to remove them?
6 years 7 months ago #212915 by rich
Maybe it's related by your Kunena template. I cannot see on your image which template you use.
6 years 7 months ago #212916 by coldwire
It's Kneat by Roundtheme
6 years 7 months ago #212923 by rich
I'm sorry, but for this template I don't know a solution.
