Question Kunena Login Issues
6 years 8 months ago #212532 by RPhilMan1
We currently use Kunena on our website privately so only registered users can access and view it. An issue has come up where if a user is not logged in, the "please log in" message is displayed but there is nowhere to click or actually login. As a test, if I set registered users only to no and access the page and then login, I am able to get through. Then I can reset the option to only allow registered users and after deleting cache I am able to still access the forum. So the issue seems to be when a user is logged out initially, they cannot actually login anywhere when they try to access the forum. Attached are screenshots and the configuration report.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 768M | Max file upload: 128M
Joomla default template details : rt_clarion_responsive | author: RocketTheme, LLC | version: 1.11 | creationdate: November 10, 2017
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.2 | creationdate: 2018-12-11
Kunena template params:
Kunena version detailed: Kunena 5.1.16 | 2020-03-17 [ Pallene ]
Plugins: None
6 years 8 months ago #212538 by rich
Replied by rich on topic Kunena Login Issues
Create a language override and add links to your login page. docs.kunena.org/en/languages/language-overrides
Enter the language constant COM_KUNENA_LOGIN_FORUM
and in the text field add your text along with html links like
Only community members can participate in this forum. You must <a href="Link to your register page">register</a> or <a href="Link to your login page">log in</a> to contribute.
6 years 8 months ago - 6 years 8 months ago #212547 by RPhilMan1
Replied by RPhilMan1 on topic Kunena Login Issues
rich wrote: Create a language override and add links to your login page. docs.kunena.org/en/languages/language-overrides
Thank you very much for the response. I was able to use the language override function in Joomla (thank you by the way as I did not know of it) and changed the text. However, I do not know a direct link to login to use as the URL. So what I ended up doing is copying the HTML from the page source code of the login function and pasted it into the language override. Now the login feature appears on the message. Problem solved! I really appreciate the help.
Last edit: 6 years 8 months ago by RPhilMan1.
Time to create page: 0.158 seconds
