Question Cache and User Sessions Issue
6 years 10 months ago #211933 by nickza
Hello.
I have recently migrated a Joomla Kunena website to a new server and I think something is wrong with my cache/session settings.
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 1024M | Max file upload: 64M
Joomla default template details : it_365news | author: InspireTheme LTD | version: 1.6.0 | creationdate: May, 2015
Kunena default template details : | author: | version: | creationdate:
Kunena template params:
Kunena version detailed: Kunena 5.0.11 | 2017-09-02 [ Kinkajou ]
Third-party components: UddeIM 3.4
Plugins: Search - Kunena Search 5.1.0 | Content - Kunena Discuss 5.1.0
Modules: Kunena Latest 5.1.0 | Kunena Stats 5.1.0 | Kunena Login 5.1.0 | Kunena Search 5.1.0
Some users get logged out after around 15 minutes, and they cannot access the server entirely, but then after a few refreshes, it works again
My questions are:
1. What are the best cache settings to use (default)
2. What are the best cache setting on joomla to use (default)
I would like to acheive that to at least have a starting point.
Thank you
6 years 10 months ago #211935 by rich
Replied by rich on topic Cache and User Sessions Issue
Kunena 5.0.11 is not supported anymore. I'm not sure if this version still works correctly with Joomla 3.9.13. If you upgrade Kunena, do it on a test page first.
It seems it's chosen the default session time of Joomla. Joomla and Kunena session times must be set to the same time period (for Joomla in minutes and Kunena in seconds).
The following user(s) said Thank You: nickza
6 years 10 months ago #211936 by nickza
Thank you.
So my next steps should be:
1. Backup
2. Upgrade Kunena
3. Double-check cache settings on both Joomla and Kunena
6 years 10 months ago #211943 by rich
No, the Session Lifetime must be the same.
6 years 10 months ago #211949 by nickza
Understood. I have made the changes and they are both now 1800 which seems to be the default.
Thank you so much for your assistance and advice. I will be upgrading Kunena and it seems the Joomla version also requires updates.
Thank you.
Time to create page: 0.156 seconds
