Question Category Icon Sizes
7 years 2 months ago #211281 by chiefkeith
I'm using FontAwesome for my Category icons, but they're too big...
How can I resize them?
7 years 2 months ago #211297 by rich
Replied by rich on topic Category Icon Sizes
You can adjust the icons via css. Use your browser tool to find the correct code and adjust the font-size for this column. If you want more help, then post a link to your forum please, otherwise it's no possible to help exactlier.
7 years 2 months ago #211298 by chiefkeith
Replied by chiefkeith on topic Category Icon Sizes
I changed it from FontAwesome to Bootstrap and now it’s smaller but I still need help. I tried to use the inspector but I couldn’t find where to change the values.
www.broncofanatics.com/forum
7 years 2 months ago #211299 by rich
You are sure they are to big? For me are the icons to small.
Try this code in your custom.less
td.span1.center.hidden-phone .svg-inline--fa { height: .9em; }
Result should be
7 years 2 months ago #211301 by chiefkeith
Those are the results that I'm looking for, but I tried the code you supplied and it didn't work. I also changed the height value to 2em just to see if there would be any noticeable change, and there wasn't. Any other suggestions?
7 years 2 months ago #211302 by rich
I can see the difference but only on the first both icons so it was the cache. Enter my code again, then empty the Joomla and browser cache.
I see in your custom.css
.svg-inline--fa.fa-w-20 { height: 2em; }
It's not the same code as I've suggest. You can also use your code, but then you need for the other icons extra codes. Your icons have not all the same size. So you need it for
.svg-inline--fa.fa-w-12
.svg-inline--fa.fa-w-16
.svg-inline--fa.fa-w-18
