Question Kunena ignores it's own template and uses wrong CSS
6 years 9 months ago #211001 by laukejas
I just installed Kunena into my website that uses a custom-made template. For whatever reason, Kutena tries to apply that template to itself, rather than using the template that is selected in the Kutena configuration.
Here is the link to my website forum:
vaterlinija.lt/index.php/forumas
As you can see, it is a total mess. I am using default Kutena settings, though I went through them, but I couldn't find the option to ignore my template CSS and use the Kutena one, that many other Joomla plugins have.
What am I missing? Can someone please advise?
6 years 9 months ago #211013 by Slacker
Kunena can look strange if you dont enable bootstrap in Kunena Template settings.
6 years 9 months ago #211014 by laukejas
Slacker wrote: Kunena can look strange if you dont enable bootstrap in Kunena Template settings.
You mean Kunena Forum -> Templates -> Crypsis -> Advanced -> Load Bootstrap css? I set it to Yes, but nothing seems to change on the website after saving the configuration...
6 years 9 months ago #211021 by Slacker
Have you emptied the cache in your browser or hit F5. If you use JCH Optimize or similar you have to empty JCH in cache also.
6 years 9 months ago #211022 by laukejas
Slacker wrote: Have you emptied the cache in your browser or hit F5. If you use JCH Optimize or similar you have to empty JCH in cache also.
Yes sir. I have. I even tried it on different computers. Still the same, as you can see from my link, it just doesn't look right.
6 years 9 months ago #211023 by Slacker
