Question How to make Mark All Read link available when not using drop-down menu
7 years 3 months ago #210934 by tcn
I would like to make the Mark All Read option available to our users. Preferably I would like to add this option to the menu as a custom entry. I'm looking for some advice on how to go about this.
Per category there is an option to mark all topics/posts as read in that category and all sub-categories. From the link that is provided by the button, I know how to construct the URL to mark all posts in all categories as read. I also know that this option is provided in the (user?) drop-down menu if enabled. However, due to issues with the menu being displayed correctly in the template we are using, we decided to not use the built-in Kunena menu. Instead we publish the menu in the header position for people to navigate our forum.
Unfortunately, there is no menu item for Mark All Read provided and I have been unable to figure out a way of constructing a custom menu entry that would add the same functionality. Is there such a way? If not, is it possible to have that menu item added in a future release? I think it should be a simple task. We would be willing to sponsor that feature if our budget allows for it.
Constructing my own custom menu entry probably fails because I need the session token to construct the URL. Is there a way in Joomla/Kunena to retrieve that token?
Any help will be greatly appreciated. Thank you very much.
Time to create page: 0.097 seconds
