Question BBcode Modal Question
7 years 4 months ago #210785 by PhilF51`
Using Crypsis when the modal bar is clicked it jumps down to bottom of editor over the attach button. Is this intended? Is there some code to change? On this Kunena forum it jumps up on the editor field. Not sure which is best for mobile devices
7 years 4 months ago #210795 by rich
Replied by rich on topic BBcode Modal Question
Try it with different mobile devices. It depends on the screen size and also of your Joomla template. You would have to address the appropriate bootstrap code. Example:
@media (max-width: 767px) div.modal.fade { your changes: !important; }
7 years 4 months ago #210796 by PhilF51`
Replied by PhilF51` on topic BBcode Modal Question
Thanks Rich. so dependent on the device. I will try it on various screens
