Question Error message when searching component in backend
7 years 6 months ago #210244 by diwou
If I call up the search under Components in the backend, I immediately get the error: "0 Call to undefined method Joomla\CMS\Application\AdministratorApplication::getP"
I can only fix this if I deactivate the Kunena Search Plugin and delete the search results. If I activate the Kunena plugin again, it will work for a few hours and the error will come back.
So I can either use the plugin, but I don't know what to search for or I have to deactivate the plugin.
The bug has been reported here several times, but I have not found a solution here.
htaccess: Exists | PHP environment: Max execution time: 192 seconds | Max execution memory: 768M | Max file upload: 256M
Joomla default template details : | author: | version: | creationdate:
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.2 | creationdate: 2018-12-11
Kunena template params:
Kunena version detailed: Kunena 5.1.12.1 | 2019-04-22 [ Kerberos ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.1.1 | Content - Kunena Discuss 5.1.1
Modules: Kunena Search 5.1.1
