Question Crypsisb3 video button doesn't work in editor
7 years 9 months ago #208117 by jeyjey
Hi, IN the Crypsisb3 editor the video button opens a modal popup, but it not insert the bbcode. If insert the bbcode manually it works. In the following example I inserted succesfully a vimeo video. Kunena shows perfectly the video. So I think it should be an editor issue. What is the file I must edit? See the example here: Ideeperilgiglio
Here you are the forum config.
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 768M | Max file upload: 128M
Joomla default template details : joomspirit_127 | author: JoomSpirit | version: 2.0 | creationdate: 01/11/2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.1.8 | creationdate: 2018-12-30
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Plugins: None
7 years 9 months ago #208131 by rich
I can't reproduce this issue. Is it only with videos or also if you want enter a link?
Could be a conflict with a script. Your link to the video is not informative, I haven't no access to the editor with it
7 years 9 months ago #208133 by jeyjey
Thanks to your interesting in this issue. I try to describe unless I have to make a video about it. When I copy a vimeo or youtube sharing link I go to the kunena editor and I write a message to post in the forum. When I want to insert a video I click on the video icon and the modal window opens. In the video modal window there is ONLY the link and not the word to write the link into. I click ok and nothing appens. No vieo link with bbcode is written in the message. If I repeat the procedure in the Joomspirit template, the video modal window is opened with TWO fields to compile. The first is a word and the second is the link. After the ok button I have the video online. Please notice that the video that is in the main message link is the Crypsisb3 template with the bbcode compiled by me: [video ....... /video]. Thanks for your patience.
7 years 9 months ago #208134 by rich
Is not necessary, all clear.
If you click on the video symbol there are two options to select. Provider or Video. If you choose "Video" I have also only this one field for the url. You see this also here on k.org. So is the problem, that the url no get to the editor text field if you click on Ok. That's why I thought, there is a script conflict.
I'm not a developer, but you can check the files in "/libraries/kunena/bbcode/"
Time to create page: 0.154 seconds
