Question A huge amount of kunena.css files in /media/templates/
7 years 8 months ago - 7 years 8 months ago #207704 by sulpher
My site is online for 5 years. During moving a site to a new server I decided to examine my site attentively and remove waste folders, so I noticed the following folder has thousands of files and 300mb of size in total: /media/templates/
Have a look at the creation date (the last column) of these files - there are less than a minute difference between creation.
The Kunena template is Crypsis BS3.
Can I remove these files? Btw, it is good to automatize this process and remove waste files from time to time.
Last edit: 7 years 8 months ago by sulpher.
7 years 8 months ago #207709 by rich
/media/templates/ This is not a path where Kunena stores files. Maybe your Joomla template has an own cache or use you a tool for page optimization?
7 years 7 months ago #208096 by sulpher
Yes, you are right - it looks like compressed files. The template is based on Warp7 framework and compression is enabled. So I will investigate the template.
Time to create page: 0.238 seconds
