Question A guests only forum
7 years 7 months ago - 7 years 7 months ago #207496 by pulsarinformatique
Hi
In my case our forum is a guests only forum. We don't want the user to create accounts.
but when a guest user wants to add a new topic he can do it but there are links to the registration and login forms.
How can we get rid of these links please ?
Moreover how can I hide / deactivate the line:
"NOTE: YOU ARE POSTING THE MESSAGE AS A 'GUEST', YOU CAN NOT EDIT THE MESSAGE OR DELETE IT"
thanks
cyril
Last edit: 7 years 7 months ago by pulsarinformatique.
7 years 7 months ago #207535 by rich
Replied by rich on topic A guests only forum
1. Go in the backend to "Kunena -> Plugins -> Kunena - Joomla Integration" and disable the Jolomla login.
2. You need a template override. You find the relevant codes in /components/com_kunena/template/crypsis/layouts/topic/edit/default.php
Comment out the line 254 and lines 263 - 267 with <!-- at the beginning and with --> at the end.
Time to create page: 0.214 seconds
