Question How to create a menu item to single topic
7 years 10 months ago #207456 by toddjharrison
Hey all,
I'm attempting to create a menu item which links to a single topic to use as a vanity URL for use in-game where typing a long URL isn't viable.
There isn't an option to do this in the Kunena menu, so thought I'd just grab the URL and create the menu item using the 'URL' option under 'System Links'.
However, this results in a 404 error when attempting to use it.
TOPIC URL: trekcommander.space/forum/fleet-command/49-danpmk-s-galaxy-map
VANITY URL: trekcommander.space/map
I've got URL rewriting turned on and the .htaccess file properly set up (as in everything else is working, etc).
Does anyone have any idea what I might be doing wrong? Everything else is working perfectly. I suppose I could create an .htaccess redirect, but would rather accomplish this using the Joomla menu system if at all possible.
Thank you all in advance for the help!
Todd
Todd Harrison
Founder: MyUAP Report
7 years 10 months ago - 7 years 10 months ago #207463 by rich
1. First open this topic and copy the url from the browser address.
2. Use "System Links -> URL" and enter the relative address such as forum/test-category-6/20-link-test (without slash at the beginning).
Last edit: 7 years 10 months ago by rich.
7 years 10 months ago #207465 by toddjharrison
rich wrote: 1. First open this topic and copy the url from the browser address.
Hey Rich,
Thanks for the reply, but that's exactly what I've been doing, and it results in a 404 error.
It throws a 404 irrespective of whether or not the TLD is included in the URL field.
No idea why.
Todd Harrison
7 years 10 months ago - 7 years 10 months ago #207471 by toddjharrison
Ok, I've done some more testing on this, and still can't figure it out. I have recreated the Kunena menu using the Menu Manager in the Kunena back-end, but this still hasn't resolved the issue. The vanity URL is still returning a 404 error.
I'll paste in the config report below just in case that turns something up.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : ja_playstore | author: JoomlArt.com | version: 1.0.9 | creationdate: Nov 29, 2018
Kunena default template details : NTS KSamurai | author: Nice Theme Store | version: 5.2.6 | creationdate: 2018-11-14
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Third-party components: Jomsocial 4.6.2
Plugins: Search - Kunena Search 5.1.1 | Content - Kunena Discuss 5.1.0
Modules: Kunena Latest 5.1.1 | Kunena Stats 5.1.1 | Kunena Login 5.1.1 | Kunena Search 5.1.1
Todd Harrison
Last edit: 7 years 10 months ago by toddjharrison.
7 years 10 months ago #207478 by rich
Your Kunena menu items are ok. But I don't think, that's a menu problem. I see no another way as a redirection, or you keep the original url. But maybe other users have a better solution.
7 years 10 months ago #207482 by Leen
Good day,
can you tell us how you make the vanity url?
with which program or plugin?
With kind regards
Leen
Time to create page: 0.166 seconds
