- Thank you received: 7
Question Quote highlight.
Unfortunately, now the quoted text is not highlighted with a frame or background.
Are there any plans to improve it?
Thanks.
Signature:
Many thanks to Rich and the other advisors.
- Thank you received: 2545
It works.
It would be quite good to separate the line "such-and-such writes" from the quote,
For example, to place it above the quote or inside the quote, but in a separate line, and maybe make it bold.
Viele Grüße
Signature:
1. Quoted text should be smaller than the response
2. Nested quotes need to be displayed consistently
For 1 I added some custom CSS to make it work including a background offset to make the quoted text more distinguishable. For 2 I have yet to find a solution. But it probably means changing code as well. In the attached image is an example of a nested quote, that demonstrate the inconsistent styling.
The outer quote has a leading "{author} wrote" , whereas in the inner quote, leading "{author} wrote" in inside the quote. I think the quoting style should be as in the outer quote, with the reference on a separate line and possible not even within the blockquote block. After all it's not part of the quote.
The corresponding HTML code looks odd:
Why is there an empty paragraph at the end?
It would also be helpful to have a separate class for the source of the quote author, e.g. "<p class="kmsgtext-quote-author">, so it can be styles differently.
Quote on my site after the changes, proposed by rich, looks acceptable, but not as beautiful as on the Kunena-forum.
But, if I understand you correctly, the solution is not offered here,
and your post is an invitation to the developers of Kunena to cooperate: -).
Signature:
lemur wrote: But, if I understand you correctly, the solution is not offered here,
and your post is an invitation to the developers of Kunena to cooperate.
I believe the issue is in the PHP code. I have been busy customizing the looks using LESS/CSS, which is save since it won't interfere with future updates. I haven't looked at the PHP code. I might, if I find the time. But my knowledge of PHP is limited.
So, yes, it's an invitation for the developers to have a look and improve. I'm willing to file a bug report, if that is required/desired.
