Question How can I uninstall Kunena & reinstall without loosing my data ?
7 years 4 months ago #207073 by Chacapamac
I ask because i cannot have my user menu showing after the last upgrade...
Thanks in advance!
7 years 4 months ago #207089 by rich
You don't need to uninstall Kunena. If you delete all Kunena menu items and restore again, it should help.
docs.kunena.org/en/troubleshooting/menu-issues (use the trash-burn-build technique.)
7 years 4 months ago - 7 years 4 months ago #207099 by Chacapamac
Thanks Rich, I did it! : :laugh:
I did it on a multilingual site (English & French) — Kunena 5.1.8
This is what I did (Your trash-burn-build technique)
Trash-burn-build technique:
1. Trash all existing menus and menu items that relate to your Kunena forum.
2. Empty the menu trash.
3. Use the Kunena Dashboard: Tools -> Menu Manager -> Restore Kunena Menu facility.
4. Publish the menu item created for you in your top-level/main menu.
Note for others:
When I went to the menu manager I saw that I have a “Invalid Menu Items” that I didn’t find at first, it was not trash but “unpublished” be sure to hunt them all.
Notes for multilingual sites: (e.g French/English)
• When you restore the menu (in 3) you get a Kunena menu created but set with “All language” - You need to changed it (in my case) to English
• You need to create the french equivalent menu (remember that you need different alias on all that) — I use the Joomla Batch tool to copy from the original menu (now for the english side) all the “Menu Items” to your newly created french menu and add the french language to them.
• Now you can rename your Menu Items name to reflect the language (translation)
• When Restore Kunena Menu (in 3) an unpublished Forum Item is created in your Main Menu (All languages) - Use the batch tools to copy this menu item into your English & french menu and assign to them their own language or creating them from scratch
— Picture is my settings for my Forum menu item for my french forum
— The menu item type should be a “Menu Item Alias” link to the Home page of your french or english Kunena menu
THE ONLY OLD PROBLEM is the fact that when the menu item “Forum” is clicked it still don’t take the “Active” state. This make the entire site look unprofessional and buggy.
I’m searching a way to force the active state (php, javascript or else) when loading page base on it’s ID,
Can you help?
Last edit: 7 years 4 months ago by Chacapamac. Reason: Miss
7 years 4 months ago #207106 by rich
You need 2 menu items alias. One from the english main menu to the english Kunena menu item "Forum" and one from the french main menu to the french Kunena menu item "Forum" ( see my test page ).
Time to create page: 0.240 seconds
