Solved All categories are not showing in the backend
7 years 9 months ago #206884 by danielles
Yesterday I decided to add a couple of more categories to my forum. So I went into the administration area clicked on Kunena then Categories. It will only show 15 categories.
I changed it from 20 to all and nothing happens.
I went into PHPMyAdmin and all of my categories are there, they're just not showing up in the admin area.
I'm running J!3.9.1 with php7.2 & Kunena 5.1.8
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : wt_factory_free | author: WarpTheme.com | version: 1.0.8 | creationdate: June 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.1.8 | creationdate: 2018-12-30
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Third-party components: AltaUserPoints 1.1.12
Plugins: None
Modules: Kunena Latest 5.1.1
7 years 9 months ago #206885 by niicetheme
Hi danielles,
In the list all categories view, click to the arrow up icon. You will see all your categories.
Attachment not found
7 years 9 months ago #206886 by danielles
As you can see from the screenshot, only a certain number of categories are showing. There's no Pagination to even show more categories.
If you want I can send you a screenshot of my database showing that I have way more categories than just 15.
You can also visit: www.piratesgoldentertainment.com/community/forum and see as well that there are more than just 15 categories. I've been using Kunena since 2010, so unless something has drastically changed I'm not sure what's going on here.
7 years 9 months ago #206940 by rich
7 years 9 months ago - 7 years 9 months ago #206943 by danielles
rich wrote: www.kunena.org/forum/k5-1-support-archiv...s-anymore-in-backend
Thank you for your help in getting this resolved. In a future version will this be fixed or was this done on purpose?
Thanks,
Danielle
Last edit: 7 years 9 months ago by danielles.
7 years 9 months ago #206948 by rich
This error is already solved in the Nightly Build.
You've 3 possibilities.
Either you wait for the next update,
or you install the Kunena Nightly Build (you find this version at bottom in our download page).
But you can easy fix this issue itself.
Change in "/administrator/components/com_kunena/models/categories.php" in the line 533 the catid from 1 to 0
before
$catid = $this->getUserStateFromRequest($this->context . '.filter.catid', 'catid', 1, 'int');
afterwards
$catid = $this->getUserStateFromRequest($this->context . '.filter.catid', 'catid', 0, 'int');
Time to create page: 0.163 seconds
