Question Dep­re­cated Class
7 years 10 months ago #206590 by adink
Dep­re­cated Class was created by adink
I'm using Kunena Hyperion 5.1.7 with the Blue Eagle (kunena) and Purity (joomla) templates. It is a new installation of the forum.
I do not have google maps installed however, I'm getting this error.
Dep­re­cated: Meth­ods with the same name as their class will not be con­struc­tors in a future ver­sion of PHP; plgContentembed_​google_​map has a dep­re­cated con­struc­tor in /homepages/28/d542639280/htdocs/backup/plugins/content/embed_google_map/embed_google_map.php on line 21
I do have hdwplayer installed.
Dep­re­cated: Meth­ods with the same name as their class will not be con­struc­tors in a future ver­sion of PHP; plgCon­tentHd­w­player has a dep­re­cated con­struc­tor in /homepages/28/d542639280/htdocs/backup/plugins/content/hdwplayer/hdwplayer.php on line 16
These errors only appear with debug on However, when debug is off I get this error:
Ren­der­ing Error in lay­out Message/​Item: reCAPTCHA plu­gin needs a site key to be set in its para­me­ters. Please con­tact a site admin­is­tra­tor.. Please enable debug mode for more infor­ma­tion.
Re-captcha is configured with site key in Joomla. It all seems very strange to me, hope I can get some help. Thanks in advance!
7 years 10 months ago #206592 by rich
Replied by rich on topic Dep­re­cated Class
Please see this topic: www.kunena.org/forum/blue-eagle-5/154961-recapcha-issue#205530
7 years 10 months ago - 7 years 10 months ago #206600 by adink
Replied by adink on topic Dep­re­cated Class
Was that a joke? Because it sure was no remedy! Let's try another question, where is the site key for kunena located? Those are good reasons for a 403 error if there is no page to display. No post has been made on this site it is a new install. So HOW is it I am getting this error?
Last edit: 7 years 10 months ago by adink. Reason: Redefine question
7 years 10 months ago #206602 by adink
Report Configuration
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: -1 | Max file upload: 64M
Joomla default template details : purity_III | author: JoomlArt.com | version: 1.2.4 | creationdate: Nov 30, 2018
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.1 | creationdate: 2018-09-23
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Third-party components: CommunityBuilder 2.3.0
Plugins: None
7 years 10 months ago - 7 years 10 months ago #206605 by 810
Replied by 810 on topic Dep­re­cated Class
Kunena is using the default Joomla Recapatcha plugin. There the site key and private key should be set.
But on your config I see that the option is turned off. So it should not load the captcha plugin.
Please update kunena (v5.1.8) and Blue Eagle Template (v 1.5.2) and check if the issue has been resolved.
Last edit: 7 years 10 months ago by 810.
The following user(s) said Thank You: adink
7 years 10 months ago #206607 by adink
Thank you! Please forgive me, I just found the configuration option! I will comply and come back to close the issue.
Time to create page: 0.164 seconds
