Question Low level security breach - Option "Hide Replies For Guests"
7 years 11 months ago #205419 by Kubik-Rubik
Hey guys,
if the mentioned option is set to "Yes", then the entries are removed properly in the article view but the content is still partly visible in the tooltips of the list overview. Example:
Please fix asap!
Cheers
Kubik-Rubik Joomla! Extensions
kubik-rubik.de
7 years 11 months ago #205451 by 810
I have solved the issue, its on the nightly build.
