Question 0 users 0 guests
- romagromov
- Senior Member
Download Free Software for Windows absolutly free.
Else try to change the setting on kunena configuration extra - userlist
- romagromov
- Senior Member
Not helps.810 wrote: mhh try cleaning your joomla cache files.
What you talking about?Else try to change the setting on kunena configuration extra - userlist
- romagromov
- Senior Member
Still have problem with this.
I checked and cleaned kunena_session table
It not helps.
I added Who is online Joomla module and it displays correct data
I've checked setting in Kunena - All looks fine
Also this settings
So, I have no any ideas how to fix it.
- Thank you received: 2545
