Question POSTS DO NOT DISAPPEAR WHEN USERS WHO HAVE PUBLISHED THEM DELETE THEIR PROFILES
8 years 1 month ago #204805 by Morenari
I have got integrated the 5.1.2. version of Kunena Forum in my Joomla site, I have discovered an issue with users who have deleted their profiles in the website. Their profiles disappear whereas their posts published on the kunena forum do not disappear . When i click these posts i also can see their authors as guest users . I have tried to delete these posts by investigating the kunena forum configuration, security measures and so on.. but i have found nothing in order to delete these posts and nothing that let me solve this issue.
8 years 1 month ago #204839 by rich
Users can remove the account on your page itself? The user management is handled by Joomla and Joomla can't delete Kunena messages.
If you ban a user via Kunena, you can delete all his posts at the same time. But that is not possible anymore, if you delete a user account previously.
Now you can only use the search option (search by user name) and all listed messages delete one by one.
The following user(s) said Thank You: Morenari
8 years 1 month ago #204846 by Morenari
Many thanks Rich for your reply. I expressed wrong, i meant users who have deleted their profiles when logging into their accounts . And the problem is that i can´t delete their posts because obviusly their profiles do not exist. If i pay attention to their posts, i can see that their authors appear as guest users (but they were not guest users when they published their posts) Then there is not way, or i do not find the way to find guest users by using search tool so i can´t delete their posts.
8 years 1 month ago #204851 by rich
Ah.. now I understand your problem. The problem occurs when a user remove his profile. That is possible if you use the privaty plugin for the new gdpr. At the moment I see no satisfying solution. I have only a workaround for you, if you find randomly guests messages.
Example from your image:
User Denver37 is listed as guest. Now search by user name Denver37 and you see all messages from this user.
We had a discuss about your problem and will add a option to find messages, where the profiles have been removed.
