Question Many js error ... editor is down attachement is down ...
8 years 1 month ago #204785 by micker
hello
after update ...
editor is killed, attachement is killed ... many js error but don't understand why !
Failed to load resource: the server responded with a status of 404 (Not Found) frontediting.min.js?v=7.7.1:6 Uncaught ReferenceError: jQuery is not defined at frontediting.min.js?v=7.7.1:6 main-min.js:1 Uncaught ReferenceError: jQuery is not defined at main-min.js:1 jquery.caret-min.js:1 Uncaught ReferenceError: jQuery is not defined at jquery.caret-min.js:1 at jquery.caret-min.js:1 jquery.atwho-min.js:1 Uncaught ReferenceError: jQuery is not defined at jquery.atwho-min.js:1 at jquery.atwho-min.js:1 topic-min.js:1 Uncaught ReferenceError: jQuery is not defined at topic-min.js:1 edit-min.js:1 Uncaught ReferenceError: jQuery is not defined at edit-min.js:1 jquery.wysibb-min.js:4 Uncaught ReferenceError: jQuery is not defined at jquery.wysibb-min.js:4 wysibb.lang-min.js:1 Uncaught ReferenceError: Joomla is not defined at wysibb.lang-min.js:1 045fcc350a262793bc914c12e2c62c9d.js:8 JQMIGRATE: Migrate is installed, version 1.4.1 57060-afficher-la-description-de-la-categorie-dans-la-vue-item.html:1914 Uncaught TypeError: $(...).wysibb is not a function at HTMLDocument.<anonymous> (57060-afficher-la-description-de-la-categorie-dans-la-vue-item.html:1914) at i (045fcc350a262793bc914c12e2c62c9d.js:2) at Object.fireWith [as resolveWith] (045fcc350a262793bc914c12e2c62c9d.js:2) at Function.ready (045fcc350a262793bc914c12e2c62c9d.js:2) at HTMLDocument.K (045fcc350a262793bc914c12e2c62c9d.js:2) bootstrap-glyphicons.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
thanks for any help
8 years 1 month ago #204793 by micker
