Question About avatar and photo
7 years 7 months ago #204303 by lucgiraud
I can not configure Kunea so that users and I, the administrator, can put avatars or a personal photo in the profile.
I use Joomla 3.4.8 and Kunea 4.0.12
I attach the configuration file to my message.
Thank you in advance.
My configuration :
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : yoo_avion | author: YOOtheme | version: 1.0.5 | creationdate: November 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.12 | creationdate: 2016-10-01
Kunena version detailed: Kunena 4.0.12 | 2016-10-01 [ Lima ]
Plugins: None
7 years 7 months ago #204308 by rich
Replied by rich on topic About avatar and photo
Kunena 4.0 is not supported anymore and also your Joomla installation is out of date. You should upgrade your page.
Why you have enabled all unneeded Kunena plugins if you have not installed these extensions?
Go in backend to Kunena -> Plugins and disable following plugins, it solves your problem.
Kunena - AlphaUserPoints
Kunena - Community Builder
Kunena - Gravatar
Kunena - JomSocial
Kunena - UddeIM
Time to create page: 0.254 seconds
