Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
configuration report
Question
Max. Image-Width/-height/-size in Configuration-Attachments IGNORED!
uploading an image in Kunena 5.0.14 with i. e. 1600x1863 Px results in a smaller sized image i.e. 927x1080 Px that shows up in a Lightbox, although I defined following values in the Configuration-Attachments-Section of Kunena:
Max. size of images (in Kilobytes) kB: 2000
Max. image width px: 1600
Max. image height px: 1600
I understand that an image may be resized for the posting in order to keep the layout/design of kunena forum.
But clicking on that image should open it in a lightbox with its original size!
Meanwhile I checked the uploaded files in /media/kunena/attachments/XY and compared them with the original ones!
An image with 1200x1600Px/766 KB becomes one with 810x1080Px/331KB
and
another image 1600x1863Px/1,63MB becomes one with 927x1080Px/195KB
after uploading them with the attachment-Button in Kunena although having defined following values in the Configuration-Attachments-Section of Kunena:
At the moment the only workaround seems to be to overwrite those uploaded images in /media/kunena/attachments/XY with the original sized images.
But the normal registred users of course cannot do that and it would not be reasonable for them!
Is this a BUG or why doesn´t the image-uploade feature work correctly by manipulating the images (shrinking them) against the defined image size/height/width-values?
Kunena 5.0.14 is not suported anymore.
It's not a bug. The lightbox opens only the size within the browser window. There are users which allow images with size more than 6000px. If you want to see the original size then open the image with right mouse click and own browser window.
The version number of Kunena does not matter because the BUG exists in the latest version too!
It IS a BUG because the IMAGE sizes are not manipulated in realtime dependent on any browser window sites but changed/manipulated during the UPLOAD process without considering the values for Image-Height, -Size and -Width in the attachment-configuration-section of Kunena. So the wrong size/width/height-problems derive from the fact that Kunena manipulates the files during the upload process without considering the set values in thhe attachment configuration section.
By the way: I have a 4K-Screen on which surely a lightbox window with 1600Px width can show up including a 1600Px-Image without any problems.
