Question Do not show ipaddress in frontend
8 years 3 months ago #204010 by polleke
Hi you all,
i would like to disable showing the ipaddress in the front end. I cannot find any parameter to do so.
So only disable in frontend, not disabling receiving ipddresses.
regards Jan
8 years 3 months ago - 8 years 3 months ago #204012 by rich
The IP addresses see only Admins and/or Moderators. There are two options in the configuration.
Configuration -> tab Frontend -> Hide IP Addresses From Moderators = Yes/No
Configuration -> tab Security -> IP Address Tracking = Yes/No (disabled it complete)
Last edit: 8 years 3 months ago by rich.
The following user(s) said Thank You: polleke
8 years 3 months ago #204013 by polleke
hi Rich,
thanks foor your answer. That works fine.
regards Jan
8 years 3 months ago #204014 by rich
This option disabled the IP Tracking complete, also in the backend.
