Question Conflict offcanvas?
8 years 3 months ago #203829 by warlocksp
Good afternoon,
Tell me please,
Joomla 3.8.11, Kunena 5.1.1, the Floox template from JoomShaper
1. Missing offcanvas in the forum?
Can in the settings switch, did not find.
Screenshot: "on-offcanvas".
2. There was an error only on Desktop, and in Mobil there is no this error?
Notice: Undefined variable: module in #####/html/mod_menu/default_component.php on line 52 Notice: Trying to get property of non-object in #####/html/mod_menu/default_component.php on line 52
This is just a warning and can be turned off. But how to fix it, and not turn it off.
The code in this line, screenshot "error-52":
if(($module->position == 'offcanvas') && ($item->deeper)) { echo '<span class="offcanvas-menu-toggler collapsed" data-toggle="collapse" data-target="#collapse-menu-'. $item->id .'"><i class="open-icon fa fa-angle-down"></i><i class="close-icon fa fa-angle-up"></i></span>'; }
8 years 3 months ago #203835 by 810
Replied by 810 on topic Conflict offcanvas?
Is the error come from the template? you marked the main part on the screenshots. I don't know where these files are from now, from the main menu or from the joomla template override.
You should contact the joomla developer.
8 years 3 months ago - 8 years 3 months ago #203855 by warlocksp
Replied by warlocksp on topic Conflict offcanvas?
Redefining the Kunena template - no.
Template "protostar" - the error is left, not outputting offcanvas.
Last edit: 8 years 3 months ago by warlocksp.
7 years 10 months ago #206739 by Alessandra Ballarini
I've the similar error in my Kunena forum (Crypsis Free Template). What Can I do to fix this problem? I've sent some screenshots.
These are the log note for the same problem:
1.
{"type":1,"message":"Allowed memory size of 134217728 bytes exhausted (tried to allocate 163840 bytes)","file":"\/home\/spraut63\/public_html\/bimgenius.net\/libraries\/src\/Language\/Language.php","line":777}
Thank You
Alessandra
This is my Report Configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : shaper_educon | author: JoomShaper.com | version: 2.6 | creationdate: Feb 2017
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.8 | creationdate: 2018-12-30
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Plugins: None
Time to create page: 0.161 seconds
