Question From Localhost to remote host, Kunena 404 error
8 years 4 months ago #202731 by eagard
Hi. I downloaded and installed Kunena this week. Worked fine on the localhost, but I get a 404 error on the remote site. I already reinstalled Kunena and created the menu links afresh. Still, no dice. I get a 404 error each time. What might be happening?
8 years 4 months ago #202733 by 810
Are you using any sef components? or the basic joomla sef.
8 years 4 months ago #202735 by eagard
I checked the plugins. There is is jomla sef enabled, as well as the eDocman sef enabled. eDoman is a document management component. There are no others.
8 years 4 months ago #202736 by eagard
Here is the configuration report configuration:
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 768M | Max file upload: 128M
Joomla default template details : rt_callisto | author: RocketTheme, LLC | version: 1.4.1 | creationdate: January 26, 2018
Kunena default template details : NTS KMax | author: Nice Theme Store | version: 5.1.1 | creationdate: 2018-07-18
Kunena template params:
Kunena version detailed: Kunena 5.1.2 | 2018-07-15 [ Charon ]
Third-party components: Jomsocial 4.5.6
Plugins: None
8 years 4 months ago #202737 by eagard
Here is the report configuration:
Plugins: None
Here is the report configuration anonymous:
Plugins: None
8 years 4 months ago #202744 by 810
Could you try with the crypsis template.
Time to create page: 0.217 seconds
