Question New Posts email notification in a read-only forum!
8 years 4 months ago - 8 years 4 months ago #202550 by dirk.potyka
Hello "810". First at all thank you very much for checking this!
Please find attached the configuration report. The only change which I did the past hours was to disable the auto email notifications. At the time it was set on I got spam mails but for the moment not.
In general everybody can display but only registered people (+manager/super user) can open topics or write answers.
Now it's 1 am in the morning here and maybe I became blind or to tired but can't find the log section. Where exactly in "configuration is it" ?
Rergards
-Dirk
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 200M
Joomla default template details : Pulse | author: Crosstec GmbH & Co. KG | version: 1.1.1 | creationdate: November 2014
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.2 | creationdate: 2017-01-09
Kunena template params:
Kunena version detailed: Kunena 5.1.1 | 2018-06-10 [ Belinda ]
Plugins: None
Last edit: 8 years 4 months ago by 810.
8 years 4 months ago #202551 by 810
1) please update blue eagle template to 1.5.0 RC3
2) config - users- Define if you want to log action or moderation set to "Yes"
3) Which category setting do you use: access level or usergroups
8 years 4 months ago #202566 by dirk.potyka
1.) I will update to blue eagle 1.5.0 RC3 today night. PS: Is there any way to get an auto reminder like for other new software versions ?
2.) It's now activated
3.) It's user group based. Typically all is handled by "Registered user"
I also attached a sample of these spam mails. Since yesterday afternoon I did not get any new spams so far.
Regards
-Dirk
8 years 4 months ago - 8 years 4 months ago #202600 by jtcarlin
Here is my report. I use access level.
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : rt_protean | author: RocketTheme, LLC | version: 1.1.1 | creationdate: February 13, 2017
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.3 | creationdate: 2017-02-04
Third-party components: UddeIM 3.9
Plugins: None
Modules: Kunena Latest 5.1.0
Last edit: 8 years 4 months ago by jtcarlin.
8 years 4 months ago #202603 by 810
I think I see the issue.
Please Update to Blue Eagle 1.5.0 RC3. You can install the package from the blue eagle page.
8 years 3 months ago #202616 by dirk.potyka
The update to 1.5.0 RC3 is now complete and the auto notifications have been re-activated.
I keep you posted here if I still receive spam or if everything is okay.
Thank you for your support !
Time to create page: 0.194 seconds
