Question kunena fatal error after update Joomla 3.8.8
7 years 11 months ago #199854 by tvfan
today I updated my Joomla Version to 3.8.8. And now I get
a fatal error when I try to open kunena (Version 5.1.0) from the frontend.
Here is the error description:
"type": 1,
"message": "Call to undefined function funcTagBuilder()",
"file": "/mnt/hp/cm/aa/el/www/website/templates/4x4_2018_3/html/mod_menu/default_component.php",
"line": 60
Any ideas?
TVFAN
7 years 11 months ago #199947 by tvfan
after changing the templates in kunena I get the following error when I use crypsis template. If I change to
purple pirate template - everthing will work fine
0 - load error: failed to find /mnt/hp/cm/aa/el/www/guitarcloud/components/com_kunena/template/crypsis/assets/less/crypsis.less
By the way, I have build my template with themler
TVFAN
7 years 11 months ago #199959 by 810
funcTagBuilder is a artiseer template issue, try to contact that they need to fix that.
purple pirate template is not developed by us, and needs some improvements. Ask the developer to update.
Time to create page: 0.238 seconds
