Question How are topic icons generated?
8 years 7 months ago #198973 by Pinkeltje
Kunena 5.0.14
I want to add an extra topic icon, but can't find where they are generated.
<td class="col-md-1 hidden-xs center"> <a href="/forum/35-category/54904-topictitle"><img src="/media/kunena/topic_icons/default/system/unanswered.png" alt="unanswered"></a> </td>
8 years 7 months ago #198975 by 810
Replied by 810 on topic How are topic icons generated?
default set is media\kunena\topic_icons\default\systemicons.xml, but it will be updated on a new update, so please copy the default dir, and rename it. then open the systemicons.xml and change the name of the set (on the xml file) and add the new icon.
8 years 7 months ago #198976 by 810
Also then you need to edit the category option to use the correct icon set.
8 years 7 months ago #198978 by Pinkeltje
I already have an override. But I can't find out which part of the code defines which icon is shown. We have a plugin that allows users to mark a topic as solved, and I would like to add a different icon to solved topics.
Time to create page: 0.099 seconds
