Solved Restore a deleted user
Thanks in advance to your help.
And is it possible for the site administrator to edit avatar of another user?
Thank you for help, I am just a beginner in Joomla. I am ready to donate to Kunena development.
Have you experience with phpMyAdmin?
1.) Open the __user table with phpMyAdmin and add a new user
Add all relevant informations from the deleted user in the fields (such as ID, register date and so on..). You find this informations in your backup file if you to open this with a text editor such as notepad plus.
2.) Add this user ID to the table *__user_usergroup_map
3.) Go in backend to Kunena -> Tools and to synchronize the users and recount all statistics (that's all, the user should be back again).
Important! Create a new databse backup previously! For interventions in the database, I take no guarantee! If a mistake happens it can to destroy the entire page!
I have a similar story. One administrator has deleted the user from Joomla.
I created a new user with the same name and username again and restored his previous ID in the database in the #__users and #__user_usergroup_map tables.
All posts of this user are saved in the database, since the forum was not cleaned with Kunena tool afterwards.
The "name" and "userid" fields in the _kunena_messages table contain the correct (old) name and id.
But KunenŠ° considers this user as new (synchronization did not help) and does not connect this user with the posts written by him.
Question.
Is it possible to attribute to the user his posts (several hundred) using the manipulations in the tables of kunena?
P.S. in _kunena_topics table "userid" (f.e., first_post_userid) and "name" (first_post_guest_name) are also correct.
Signature:
Many thanks to Rich and the other advisors.
I've tested it.
1. Created this user with same name and user name in the Joomla backend (it will create all user relevant entries).
2. Note down the user ID from the Joomla user manager
3. Adjusted the ID in the tables *__users and *__user_usergroup_map (group ID 2)
All is corrct again, so i think, you should check it again.
I've as you suggested
1. Created this user with same name and user name in the Joomla backend (ONLY E-Mail is another, becouse of i cannnot use the old email).
2. Note down the NEW user ID from the Joomla user manager
3. Changed the NEW ID in the tables *__users and *__user_usergroup_map (group ID 2) to old ID.
It's OK now. ))
Signature:
