Question Customization
8 years 8 months ago #198806 by jhoefs
Customization was created by jhoefs
Hello, noone has been able to answer this yet, so if you can help me with it, I will be super stoked. B)
Running Kunena on a Helix3 framework. I want to customize the forum 'start' page (the place the user is taken when they first enter the forum section) so that it displays:
1. List of topics in category named "Blue"
2. list of sub-categories in section "White"
It's very important I find a way to do this, either through template overrides, custom module placement, or some other means, for the flow of the site. Any ideas?
8 years 7 months ago #198870 by jhoefs
Replied by jhoefs on topic Customization
Forgot this:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : shaper_helix3 | author: JoomShaper.com | version: 2.5.1 | creationdate: Jan 2016
Kunena default template details : Clean | author: Kunena Team | version: @kunenaversion@ | creationdate: @kunenaversiondate@
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Third-party components: CommunityBuilder 2.1.3
Plugins: Search - Kunena Search 5.0.3 | Content - Kunena Discuss 5.0.3
Modules: Kunena Login 5.0.3 | Kunena Search 5.0.3
8 years 7 months ago #198886 by 810
Replied by 810 on topic Customization
You can select the categories on the kunena config. -> frontend -> Category List in Recent Topics
8 years 7 months ago #198894 by jhoefs
Does anyone have an answer to this?
Is there any way to assign different templates to different category streams in Kunena? If not, why not? This feature would solve many different problems in Kunena in terms of customization, and I strongly advocate it in future versions.
8 years 7 months ago #198900 by rich
Replied by rich on topic Customization
I'm sorry, but different templates for individual categories are not possible. You can use only different colors for chosen categories.
docs.kunena.org/en/manual/backend/catego.../coloured-categories
