Question Emoticons display issue on topic create
8 years 8 months ago - 8 years 8 months ago #198369 by buzz50
Words are appearing under the emoticons during topic or reply create for one user on his iPad
Any suggestions?
Kunena 5.0.11
[img
Mike
Buzz50 Seniors
'Head Buzzer'
Last edit: 8 years 8 months ago by buzz50.
8 years 8 months ago #198377 by rich
Exists this problem only with Blue Eagle or also with Crypsis? If it's a Blue Eagle problem, I will move this topic in the right category.
But it will hard to find the cause, when this problem only occur at this one user.
If you want, you can create a account for us, maybe we can see the problem. Normal registered user would be enough. You can use the confidential tags (padlock symbol), then only you and moderators can see the access data.
