Question Disabling JomSocial in favor of Kunena
8 years 9 months ago #197886 by Murnane
My site had become very complicated with members communicating and posting videos via both JomSocial and Kunena. I am considering rebuilding the site with just Kunena. I have copies of my site running on localhost and I'm experimenting with different configurations.
Is it possible to turn off or uninstall JomSocial so that the site is only integrated with Kunena?
If it is, how would I do this? Thanks in advance guys for any assistance you can give on this subject :)
8 years 9 months ago #197893 by rich
JomSocial is a own extension and run with and without Kunena. The same is with Kunena. JomSocial is not needed and you can uninstall it. But for your tests I recommend, disable the plugin Kunena JomSocial integration (Backend -> Kunena -> Plugins). You can also disable JomSocial in "Extensions -> Manage -> Manage". Enter as search keyword "JomSocial and disable the hits. So you can test it with and without JomSocial.
Time to create page: 0.098 seconds
