Question Category selection drop-down does not show currently-selected category
8 years 10 months ago #197697 by RenniePet
This is a bit difficult to describe, but here goes ...
Here's what my category selection drop-down looks like when dropped down:
[strike] [/strike]
If the last category ("All questions and answers") is selected, then the situation looks like this:
Note that the "All questions and answers" category is being shown, but the category selection drop-down is showing "Dansk (Danish)", which is incorrect, or at least not synchronized with what is being shown.
This could maybe be considered to be a minor cosmetic problem, but it has the unfortunate result that if the user does want to switch to the Danish section of the forum, then it's not possible. If you click the down arrow, and then click on "Dansk (Danish)", then nothing happens, because Kunena thinks the user has not done anything (the drop-down selector is still showing what it was showing before), so Kunena does not switch to the Danish categories. The user is left scratching his/her head and wondering what he/she needs to do to get to the Danish section of the forum.
I think the correct implementation should be that the drop-down control is set to show the current category selection.
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 15M
Joomla default template details : merlinia | author: Rqoon | version: 1.0 | creationdate: 4/30/2017
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.13 | creationdate: 2017-12-31
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Plugins: None
