Question categoryMissingAlias - TEST FAILED! - What now?
8 years 10 months ago - 8 years 10 months ago #197645 by shoulders
I have a category that is showing the wrong alias.
My Forum is here quantumwarp.com/forum
The faulty Category is QWcrm because it keeps pointing to quantumwarp.com/support .
So I ran the 'Diagnostics' in the tools section and it showed 1 error in categoryMissingAlias which matches up with my error.
There is no link to correct the issue and I can not find any documentation on how to fix this checking:
www.kunena.org/docs/en/manual/backend/tools/diagnostics
Kunena Forun Search
Github
I have check the menu items in the rest of joomla and one was pointing to this category with the alias of support so i removed this and now the alias is corrected in kunena but I do not know how to fix the error report by the diagnostic tool.
Thanks for any help.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : g5_helium | author: RocketTheme, LLC | version: 5.4.22 | creationdate: December 12, 2017
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.4 | creationdate: 2017-09-02
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.0.3
Last edit: 8 years 10 months ago by shoulders.
8 years 10 months ago #197655 by xillibit
When you look in the Kunena categories manager, for the category QWcrm do-you see more than one alias ?
8 years 10 months ago - 8 years 10 months ago #197657 by shoulders
Hi xillibit,
I have been through every category and removed any extra aliases.
I found that I had a Joomla menu item causing the abnormal SEF Alias issue.
However I still have the categoryMissingAlias error and no way of working out which one.
Things seem to be working ok (but no live yet)
Time to create page: 0.154 seconds
