Question Very confused about templates
8 years 10 months ago #197603 by RenniePet
I'm considering trying out kunena, and have spent some time reading the manual and this forum. But one thing I can't seem to understand is the whole business of templates.
Is kunena compatible with the Joomla Protostar template?
Is a kunena-specific template needed? On top of Protostar, or instead of Protostar for the web pages generated by kunena?
Where do Crypsisb3 and Blue Eagle fit in?
Thanks for any enlightenment.
8 years 10 months ago #197605 by 810
Replied by 810 on topic Very confused about templates
Yes, the default template Crypsis is compatible with the Joomla Protostar. (Is based on Bootstrap 2)
No, its specific framework needed. (Boostrap 2 (crypsis,), Bootstrap 3 (cyrypsisb3), Html (Blue Eagle))
The crypsis template need bootstrap to run. If you have a joomla template does not have bootstrap included, then you have 2 options.
1) Enable "Load Bootstrap" option on the crypsis template settings. This will load the default bootstrap (2) version who is shipped with Joomla 3.x
2) Use Blue Eagle template. This template is a html based template. What means it will run on all Joomla templates. (* there can be some small css issues, depends on the css of the Joomla template)
The following user(s) said Thank You: RenniePet
8 years 10 months ago #197612 by RenniePet
Thank you very much.
May I suggest that this information be included in the documentation. (Unless it's already there, in which case I managed to miss it.)
8 years 10 months ago - 8 years 10 months ago #197658 by claudio_sbc
Excellent help.
To rockettheme template need only activate bootstrap.
Last edit: 8 years 10 months ago by claudio_sbc.
8 years 10 months ago #197762 by shoulders
Just to clarify.
Kunena uses it own templates. Kunena comes with the Crypisis template built in.
You can get some free tempaltes and some great paid templates for Kunena and I would get one as close as possible to your Joomla template and then alter it if needed.
