Question Attachments and Image Links Not Working
8 years 10 months ago #197505 by benign01
I have another issue. I am unable to add an attachment to any post. The popup appears and I select any image on my PC but nothing is added. Also when I try and use image link the link is repeated several times (see screenshot )
I have disabled jch and image recycler. I have removed pagespeed mod. What is the issue please
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : protostarplus | author: Maarten Blokdijk | version: 1.0 | creationdate: 04/13/2016
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.13 | creationdate: 2017-12-31
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Third-party components: AltaUserPoints 1.1.11
Plugins: Content - Kunena Discuss 5.0.3
Modules: Kunena Latest 5.0.3 | Kunena Login 5.0.3 | Kunena Search 5.0.3
8 years 10 months ago #197511 by rich
Your website is general not error free. You should repair first the complete page. My browser tool shows many errors on your page (see image), so it's not possible to find the cause.
8 years 10 months ago - 8 years 10 months ago #197520 by benign01
Ok so i have disabled the plugin jqeasy and now I can at least select an image but it still will not upload to post and it appaers in triplicate. Could you check again please
Last edit: 8 years 10 months ago by benign01.
8 years 10 months ago #197522 by benign01
I have tinkered with the templates bootstrap settings and now have the following showing (see screenshot ) ie the upload shows but not in the actual post. Why is this?
8 years 10 months ago - 8 years 10 months ago #197523 by benign01
I fixed this by enabling Jquery & UI in jqeasy to avoid conflicts thrown up by kunena
What i would say is that now avatars only show when one is logged out. Any ideas?
Now sorted. Strongly recommend purchase of Blue eagle template from the Kunena Guys!!
Time to create page: 0.174 seconds
