Question bbcode menue not visible on edit (menue symbols)
9 years 2 days ago - 9 years 2 days ago #196911 by jjanarnava
Hallo Community,
after a fresh installation I do not get the bbcode menue above the "Edit" field.
I could not find any entry to enable or disable this menue so far... any suggestions? Thank you!
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : Tx_Appy | author: ThemeXpert.com | version: 1.0 | creationdate: 01/02/2014
Kunena default template details : JF Simone | author: JoomForest.com | version: 1.0 | creationdate: 20.05.17
Kunena template params:
Kunena version detailed: Kunena 5.1.0-BETA1 | 2017-10-05 [ Avalanche ]
Third-party components: CommunityBuilder 2.1.3
Plugins: None
Last edit: 9 years 2 days ago by jjanarnava.
9 years 2 days ago #196917 by rich
Maybe is there a conflict with a script. But you're using a Kunena template, which I don't know. Maybe is there a conflict with a script. But you're using a Kunena template, which I don't know. Please try it with Crypsis, maybe so we can to localize the problem.
9 years 1 day ago #196930 by jjanarnava
Thank you for your response! You are right, with your template the menue it is there but the tabs are missing, just the rest of the forum does not look like supposed... The other template is JFSimone from JoomForest.com.
Is it a matter of the template design then?
9 years 1 day ago - 9 years 1 day ago #196932 by rich
You have two wrong menu items:
"Benutzer Forum" and "User Forum" in both main menus. This men items must be Menu Item Type = Menu Item Alias ( see here ).
I've visited JoomForest.com and noticed, the last update of this template is long time ago. There was many changes in Joomla as well Kunena. Maybe the template JFSimone need only a upgrade. But that should not be the importantest way at the moment.
First should the forum work correctly with the default template. Afterwards you can test and customize your own template. Otherwise you never know, is the issue in Kunena or in your template.
You should also report this at JoomForest. Errors will normally fixed if they know about them.
Last edit: 9 years 1 day ago by rich.
Time to create page: 0.156 seconds
