Question unapproved posts view links to unread posts
9 years 5 days ago - 9 years 5 days ago #196827 by hey-ai.com
Aloha all,
I recently upgraded our kunena installation and am now using the Crypsis template for the first time.
Our moderators check the listing for unapproved posts regularly:
../index.php?option=com_kunena&view=topics&layout=posts&mode=unapproved
However, the links in that listing do not link to the actual unapproved post. Instead they link to my unread posts in the corresponding thread (/unread). In this scenario I often have to go to a different page and hunt the actual post.
Is this intentional behavior? Is there a setting to change it to show the actual post that needs to be approved?
I have tried searching for this topic in the forum and didn't find anything. I apologize if this was discussed already.
Thanks for your help,
Karina
hey-ai.com
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 8M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.11 | creationdate: 2017-09-02
Kunena template params:
Kunena version detailed: Kunena 5.0.11 | 2017-09-02 [ Kinkajou ]
Third-party components: CommunityBuilder 2.1.3 | UddeIM 4.0
Plugins: Search - Kunena Search 5.0.3 | Content - Kunena Discuss 5.0.3
Modules: Kunena Latest 5.0.3 | Kunena Stats 5.0.3 | Kunena Search 5.0.3
Last edit: 9 years 5 days ago by hey-ai.com.
9 years 5 days ago #196829 by rich
Click at the left to go directly to the unapproved messages.
The following user(s) said Thank You: hey-ai.com
9 years 5 days ago #196830 by hey-ai.com
Thanks for your quick reply. This works if there are no unread posts in the corresponding thread.
However, as soon as I have unread posts, the entire thread link points to /unread instead of the unapproved post.
I didn't notice that difference before. Thanks for pointing that out. For now I can go to the thread so it's marked unread, refresh the page and click the new link.
9 years 5 days ago #196834 by rich
Thank you for this hint. It's in principle not correct, but when we remove the "New" indicator on this menu item, there is another problem. If you approve a post, you go automatically in this topic. And if you go in a topic, it will registered as read (Kunena cannot distinguished, whether you only refreshes or read a topic). So you might not go to your first unread messages anymore.
9 years 5 days ago #196835 by hey-ai.com
I get what you mean. For me as an admin I'd prefer to have the link go to the unapproved post AND have the new indicator go to the unread post. This way, if I do want to see the unread posts view, I can open the NEW (unread) link in a new tab and the unapproved one in another tab.
I'll understand if you guys don't want to change anything about it, though.
Time to create page: 0.162 seconds
