Question How to disable the dropdown menu
9 years 2 weeks ago #196758 by phmalo
I'm new to Kunena, never used it before.
My problem is, that there is a dropdown menu as seen in the picture below and i don't want that. How can I disable that?
Thank you!
9 years 2 weeks ago #196760 by rich
Please go in backend to "Kunena -> Templates -> Crypsis -> Basic Settings" and choose "Load Bootstrap css = Yes". But if you use a Joomla bootstrap3 template, then try it with Crypsisb3.
