Question Way to not show the usernames
8 years 7 months ago #195809 by cyberrick
I'd like to see if there is any way to remove the username from the lists and in the category lists. We don't want anyone to know who is making the posts.
s.nimbus.everhelper.me/share/1133030/lpq3mro6ws5vq6hbe4ap
8 years 7 months ago #195814 by rich
Replied by rich on topic Way to not show the usernames
You can use the anonymous function (Kunena -> Categories -> click on Category -> Category Settings".
Allow anonymous messages: = Yes
By default post replies as: Anonymous user
This setting is needed for all categories. But a anonymous user can't edit his messages.
8 years 7 months ago - 8 years 7 months ago #195816 by cyberrick
Thanks for your post, but nothing seems to be working for me. I made all the question sub categories set to allow Anonymous postings. I even checked the box to make it an anonymous post. It doesn't work for me. Everything I try doesn't work.
davidbenson.us/index.php/forum/index
Last edit: 8 years 7 months ago by cyberrick.
8 years 7 months ago #195817 by 810
Replied by 810 on topic Way to not show the usernames
There is a bug on the last release, we have fixed it already: github.com/Kunena/Kunena-Forum/pull/5567
8 years 7 months ago #195818 by cyberrick
I don't see any files to download at this link you gave me? Not that familiar with GitHub can you help direct me where to fine the file.
8 years 7 months ago #195829 by rich
This fixes are for templates Crypsis and Crypsisb3, so will this fix not help you. You use a template from third-party provider. I don't know, whether your template this option supported. You must ask your template author.
Time to create page: 0.272 seconds
