Question Hide Posts from Guests
9 years 2 months ago #195754 by cyberrick
We recently installed Kunena 5.0.11. We want to have guests be able to see all the categories available in the forum, but not be able to
click on a category and see and read all the posts. How can we set it up so this can happen?
Please help.
Site = davidbenson.us/index.php/forums
9 years 2 months ago #195756 by rich
Replied by rich on topic Hide Posts from Guests
You can use the setting "Hide Replies For Guests" (Configuration -> tab Security), but guests can see the first message of a topic with this option. That all posts are hidden is not possible.
9 years 2 months ago - 9 years 2 months ago #195757 by cyberrick
Replied by cyberrick on topic Hide Posts from Guests
I tried this but guest can see more than just the first - davidbenson.us/index.php/forums/confident-workshop
Here's my security configuration - s.nimbus.everhelper.me/share/1128584/ebom24c2gnoqh432s8vy
Last edit: 9 years 2 months ago by cyberrick.
9 years 2 months ago #195765 by rich
I see you use Blue Eagle. Blue Eagle was never planned for Kunena 5.x but many users wanted back the old style of this template. It is a additional work and therefore are not all features included yet. This feature will be included in Blue Eagle for Kunena 5.1
9 years 2 months ago #195770 by cyberrick
Well, I installed a new template from 9themestore.com which is recommended on the templates page. They say it is compatable with the 5.0.11 version and the feature still does not work? I really wish this worked because this will be a forum for some classes and the students will not want unregistered users to able to browse around and see their questions. Can this be custom programmed in for now?
9 years 2 months ago #195775 by rich
This has nothing to do with compatible. You need the codes for this feature on the template.
I don't know your template but it needs this code in "components\com_kunena\template\your template\layouts\message\item\default.php".
If you ask your template author, he can tell you, which line exactly you must replace. Probably there is a little difference to his and our templates. If you ask in his support page, then set a link to this topic.
