Question Attachments can't be inserted into a topic/Only one attachment for every edit
9 years 2 months ago #195048 by Kotsolis
I had 1,5 year to upgrade to Kunena latest version. Now I have version 5.0.10 and I can't insert attachments into post.
I can only Add one Attachment per post.
- When I click "Insert" nothing happens.
- In order to Add more Attachments I have to edit the topic every time and add them one by one.
Is this a known bug? How can I solve it? Create some topics in www.gameworld.gr/forum , try to add attachments and see by yourself.
Username: Test
Password: 123457
9 years 2 months ago #195057 by rich
I've tried it. The action will stopped by the browser. There is a conflict with your frames which also running on your page. My browser console shows this info: www.chromestatus.com/feature/5718547946799104
But it's interesting that the errors on your page are piling up lately. First all language files are gone, then the message about wrong or broken menu item and now this. Perhaps a general review would be appropriate.
9 years 2 months ago #195712 by Kotsolis
This is my configuration.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : Cepon | author: ThemeSoul.com | version: 1.17.3 | creationdate: 09 June 2014
Kunena default template details : JF Simone | author: JoomForest.com | version: 1.0 | creationdate: 20.05.17
Kunena template params:
Kunena version detailed: Kunena 5.0.10 | 2017-06-30 [ Junco ]
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 5.0.3 | Kunena Search 3.0.1
Please help me on this as it is very important. We upgraded from Kunena v3 to Kunena v5 and this was the first bug we saw (before all others). So no developer changed anything on the site when this bug occured. We had only like 3-4 bugs with Kunena after the upgrade and that was the first we met and the most important one.
9 years 2 months ago #195716 by rich
There are conflicts with 2 scripts:
ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js
/templates/cepon/js/head.js
If you disable these scripts, then works the upload. The head.js is from the Joomla template, date 09 June 2014. maybe it needs a update.
Time to create page: 0.155 seconds
