Question Several questions to template override and to add additional editor symbols
9 years 3 months ago - 9 years 3 months ago #194135 by Razen
I almost finished the setup of my kunema-forum, but a few questions are still open:
1) I would like to have captchas for guests only, but the options dont give me that setting. How can I realise this?
ANSWER:
- Activate the ReCaptcha Plugin in Joomla
- Set the reCaptcha Codes inside the Plugin and Save
- Setup the Captcha in the Joomla Configuration
- Activate the Captcha in the Kunema Security Config:
Display Captcha for: Guests Users and Registered Users
Captcha Challenge for Users: 0
2) I found this error message inside my error-log:
[Wed Jul 26 17:46:32.955779 2017] [:error] [pid 23375] [client 79.220.240.89:53053] PHP Notice: Array to string conversion in /home/mcheads/web/webroot/administrator/components/com_kunena/controllers/categories.php on line 456, referer: http://[].com/administrator/index.php?option=com_kunena&view=categories&layout=edit&catid=1
Is this an official known bug?
3) I would like to modify the template-file for Recent posts / Unapproved Posts, but I cant find it in the layout folder of crypsis. Which file is it?
4) I would like to move all modified files to my joomla-template to keep them secure. That's easy for the layour-files since I collected them all in the folder of my kunema-template and copied the files from crypsis if they didnt exist yet. This tutorial will help here:
www.kunena.org/docs/en/faq/template-overrides
BUT: The CSS was a mess. I had to modify those files and now I wonder, how I could copy those into the joomla-template...
/webroot/media/jui/css/bootstrap-responsive.min.css
/webroot/media/kunena/cache/jf_simone/css/kunena.css
/webroot/components/com_kunena/template/jf_simone/jf/assets/css-compiled/jf_template.min.css
Thanks a lot for all your help :)
Last edit: 9 years 3 months ago by Razen.
9 years 3 months ago #194255 by rich
Please use in the future a significant title and ask not different questions in one topic.
You should not modify the original files. Therefore it gives the custom.less . Edit the relevant codes with your browser tool (such as Firebug) and copy the edited codes to the custom.less .
9 years 3 months ago #194256 by Razen
Since I created two other threads, three on the whole, I wasnt sure if would count as spam if I create seven threads, sry.
Ok I'll seperate the CSS from the files I modified to the custom file, I guess that counts for all three files I modified?
That leaves question
#3: Template for recent posts
#2: any news about this bug?
9 years 3 months ago - 9 years 3 months ago #194258 by rich
== Topic title changed ==
I've created a own topic: www.kunena.org/forum/k5-0-support/148515...sage-in-my-error-log
What exactly do you want to change? Go to the Kunena menu and to open the menu item Recent Topics. Click on the tab Page Display and enter a page class.
Example Page Class = myrecent
Enter your changes in the custom.less such as:
.myrecent { background-color: #c2c2c2; } .myrecent .topictitle { font-size: 1.8em !important; }
(It's an extreme example, but so you can see quickly the changes)
Last edit: 9 years 3 months ago by rich.
9 years 3 months ago #194264 by Razen
I would like to add some custom php-code, that's why I look for the template in the layouts-folder...
