Question Several questions to template override and to add additional editor symbols
I almost finished the setup of my kunema-forum, but a few questions are still open:
1) I would like to have captchas for guests only, but the options dont give me that setting. How can I realise this?
ANSWER:
- Activate the ReCaptcha Plugin in Joomla
- Set the reCaptcha Codes inside the Plugin and Save
- Setup the Captcha in the Joomla Configuration
- Activate the Captcha in the Kunema Security Config:
Display Captcha for: Guests Users and Registered Users
Captcha Challenge for Users: 0
2) I found this error message inside my error-log:
[Wed Jul 26 17:46:32.955779 2017] [:error] [pid 23375] [client 79.220.240.89:53053] PHP Notice: Array to string conversion in /home/mcheads/web/webroot/administrator/components/com_kunena/controllers/categories.php on line 456, referer: http://[].com/administrator/index.php?option=com_kunena&view=categories&layout=edit&catid=1
Is this an official known bug?
3) I would like to modify the template-file for Recent posts / Unapproved Posts, but I cant find it in the layout folder of crypsis. Which file is it?
4) I would like to move all modified files to my joomla-template to keep them secure. That's easy for the layour-files since I collected them all in the folder of my kunema-template and copied the files from crypsis if they didnt exist yet. This tutorial will help here:
www.kunena.org/docs/en/faq/template-overrides
BUT: The CSS was a mess. I had to modify those files and now I wonder, how I could copy those into the joomla-template...
/webroot/media/jui/css/bootstrap-responsive.min.css
/webroot/media/kunena/cache/jf_simone/css/kunena.css
/webroot/components/com_kunena/template/jf_simone/jf/assets/css-compiled/jf_template.min.css
Thanks a lot for all your help
You should not modify the original files. Therefore it gives the custom.less . Edit the relevant codes with your browser tool (such as Firebug) and copy the edited codes to the custom.less .BUT: The CSS was a mess. I had to modify those files and now I wonder, how I could copy those into the joomla-template...
Ok I'll seperate the CSS from the files I modified to the custom file, I guess that counts for all three files I modified?
That leaves question
#3: Template for recent posts
#2: any news about this bug?
I've created a own topic: www.kunena.org/forum/k5-0-support/148515...sage-in-my-error-log#2: any news about this bug?
What exactly do you want to change? Go to the Kunena menu and to open the menu item Recent Topics. Click on the tab Page Display and enter a page class.#3: Template for recent posts
Example Page Class = myrecent
Enter your changes in the custom.less such as:
(It's an extreme example, but so you can see quickly the changes)
