- Thank you received: 2429
Question How to increase fonts size in Kunena v5 [SOLVED]
Official Kunena templates create this file automatically ( see here ), when you edit these in the backend. but you use another template.There is no custom.css file there.
Yes, if you have no entered any codes then is the file empty.Also, in my template, the custom.css file is 0 bytes.
You should not edit any files. Add the codes which you want edit in the custom.css or at the end in your Joomla template.css. You find the codes with browser tools such as Firebug (if you press F12).Any suggestions on which file to edit?
Α)In the components/kunena/custom.css ?
Β)in the templates/default/template.css ?
οr C)Ηere with this method? - docs.kunena.org/en/manual/backend/templates/edit-less , by editing custom.less ?
.layout#kunena .topictitle {
font-size: 130%;
.layout#kunena h1, .layout#kunena h3 {
font-size: 2.0em;
.layout#kunena #kbbcode-message {
resize: vertical;
font-size: 1.1em;
.header-desc {
font-size: 1.1em;
Yes, optimal is the custom.less. If you have a custom.less then use for changes in your Kunena template only this file.Ηere with this method? - docs.kunena.org/en/manual/backend/templates/edit-less , by editing custom.less ?
But it works also if you add the codes at the end of your Joomla template.css.
I've put this code, I saved, I cleared cache, and I see no changes.
Look in www.gameworld.gr/forum
Can you help? Also, I tried both Edit .css and edit .less and can't find the difference between them!
The correct path is "/components/com_kunena/template/jf_simone/jf/assets/"
The custom file in this folder is empty, therefore it cannot work.
"/components/com_kunena/template/jf_simone/jf/assets/jf_custom.css"
The file was empty, now it has your code. Still it doesn't work even if I cleared cache and cookies.
Please respond!
