Question Kunena v5: Show 10 latest forum topics
9 years 2 months ago #188327 by Kotsolis
I had this module installed in Kunena v3. Now I've upgraded and it dissapeared.
I tried to download the plugin from here:
www.kunena.org/download
Is it the "Kunena Latest Module" ? It doesn't let me install this file in the backend (I went to Extensions/Manage/Install). It just shows an error.
What do you recommend? Is there an other Kunena installation menu? Do I have to just copy the Plugin to a folder? Can't find a solution.
Thank you.
9 years 2 months ago #188334 by rich
I don't know which extension you had installed earlier.
What error was displayed?
Time to create page: 0.238 seconds
